hello have you ever created a configuration on elastic lements like a spring in which the configuration is activated you have the transition from one compression state to another?
Unfortunately the springs are perhaps a weak point of osd, it can be that version 17 with the parametrics module gives some extra possibilities, I for now when I have to draw a spring that takes different configurations within a set or simply is mounted with a certain preload I entrust myself to the "containers", who have the advantage of being default switched off (and not to be counted when you evaluate the weight of a video" while in an option
so much to make a simple example, I design a valve that in vacuum conditions has the spring all open, so save my set with the spring to rest, then I make a container inside the spring in which I put the spring copied but compressed and then I create a configuration of the axieme in which I turn off the spring to rest and I turn on the inside the container.
I capture elements to video and so when I have the axieme without active configuration I see my extended spring, when "active configuration" I see my compressed spring.
