configure a rotation in combination
  • Thread starter Thread starter mawell
mawell
Good morning.
I would like to create a configured set where I have to place another set. this together is always equal but must rotate according to the position. the file provides a repetition based on the sketch in which the axieme is placed. for each position I have to apply a rotation of the axieme to 0 / 90 / 180 / 270 degrees. I thought I turned on and off couplings based on configuration but when I change configuration the axieme goes in hyperdefinition. but if I turn off and rekindle the coupling works, unfortunately changing configuration I must always turn on and off the coupling.
How to solve? ?
in my opinion you may have only one angle coupling and between one configuration and the other changes the width of the coupling angle.
perfect!!! I got there a bit but when I tried it didn't work. In practice I had made 4 couplings that were activated and turned off according to the configuration. I think it was in conflict with the concept of 90 positive or negative grades.
I am in agreement with you that it is better to operate changing the angle, but when I put the table I do not find the column with the values of the angle (in the corner coupling) and if I change it (with option "only for the current configuration") I change it on all configurations.
Did you get that?
Do you know what column name I have to put to have that value in the table? I tried "value@angle1" but you don't recognize me.
strange that you don't find the column of the corner, if you right on the mating doesn't give you this?1643212983191.webpthen you find the column:1643213026384.webp
ah! I looked at it from table in configuration. never did that. Tomorrow I try!
in the meantime thank you very much
Here... actually does not work (see attached image). or better: I don't find that column d1 in the table. ho solidworks 2019
Do you have ideas to solve it? ?
