configure bubble diameter in separate
  • Thread starter Thread starter niki
niki
I return to creo-proe after a few years of inventor...I remember that in the config of the wf4 there were 2 rows that managed the minimum and maximum radius of the balloons (something type max balloon radius), so I avoided that the balloons had different sizes depending on the amount they contained; Unfortunately I can't find these 2 lines of the config anymore, do you know anything about it? if someone remembers the precise name of the variable I try to write it in the file and see if it works.... thanks
ciao!
max_balloon_radius
min_balloon_radius
but are found in the *.dtl file, related to drawings.
hi niki I moved the messages into a new discussion.
the subject had nothing to do with the guide to the config.pro
