conical thread... who knows??? ? ?
  • Thread starter Thread starter Stemox
Stemox
How does a conical thread occur? ....from the menu of free geometries can be realized are cylindrical helical geometries!
ariciao
I usually when I have to do a conical thread, for example regular bees, I am pleased to draw the profile of rotation, with the measures indicated in the tables and to "color" so diferso the threaded face. around there are probably a few lisp that allow you to do conical threads but I don't know about it.
If you are interested in creating a conical and non-cylidrical helid, then you must first create the conical helical spline and for this you must go in 3d curves, select spiral/form choose conical from the drop-down menu and generate your average line. to this can only create your section possibly in an orthogonal plane at the beginning of your average line and use the rototranslation in which you will choose as pl the plan containing the section and as director the 3d curve
OK, I imagined it reminding me of something like this by seeing a demo (parecchio tempo fa) of 3d curves.
The problem is that I can't use it.... I see if I understand anything.
Sorry kaji,
but does p.edition have all but all the modeling commands?? ? ?
can be activated? Annotation commands?
...what changes then from the licensed version?
I'm sorry the question, but I could use it.... .
thank you good evening.
I personally do not have the personal edition, but I think I have read that the greatest limit is that of the assemblies: maximum 60 pieces I think I have read, moreover I think that the saved files cannot be opened from any other pc, something like that and cannot be exported to other formats.
In short, the personal edition should only be used to learn how to use the software and not to produce, of course I believe that the designs can be printed both on paper and pdf.
