arimans
Hello everyone,
As for the axiemi, only the mapkey code changes, for the rest it is all the same as the one mentioned here:http://www.cad3d.it/forum1/showthread.php?t=20437just enter the update code with the following:
map excel_regen ~ command `procmdmmparams` ;\
mapkey(continued) ~ columnselect `relation_dlg` `paramsphlay.partable`1 `name`;\
mapkey(continued) ~ arm `relation_dlg` `paramsphlay.partable`2 `rowregen_input` `name`;\
mapkey(continued) ~ disarm `relation_dlg` `paramsphlay.partable`2 `rowregen_input` `name`;\
mapkey(continued) ~ select `relation_dlg` `paramsphlay.partable`2 `rowregen_input` `name`;\
mapkey(continued) ~ arm `relation_dlg` `paramsphlay.partable`2 `rowregen_input` `value`;\
mapkey(continued) ~ disarm `relation_dlg` `paramsphlay.partable`2 `rowregen_input` `value`;\
mapkey(continued) ~ select `relation_dlg` `paramsphlay.partable`2 `rowregen_input` `value`;\
mapkey(continued) ~ open `relation_dlg` `paramsphlay.partable_input`;\
mapkey(continued) ~ close `relation_dlg` `paramsphlay.partable_input`;\
mapkey(continued) ~ select `relation_dlg` `paramsphlay.partable_input`1 `yes`;\
mapkey(continued) ~ move `relation_dlg` `relation_dlg`2 29.984987 6.492077 ;\
mapkey(continued) ~ activate `relation_dlg` `pb_ok`;~ command `procmdregenpart` ;#read file;\
mapkey(continued) c:\input.txt;~ command `procmdmmparams` ;\
mapkey(continued) ~ select `relation_dlg` `paramsphlay.partable_input`1 `no`;\
mapkey(continued) ~ activate `relation_dlg` `pb_ok`;~ command `procmdregenpart` ;\
mapkey(continued) ~ command `procmdmmparams` ;\
mapkey(continued) ~ activate `relation_dlg` `pb_ok`;~ command `procmdregenauto` ;#read file;\
dove le parti in rosso sono da adattare a seconda dei casi.
