connect autocad text fields to an excel file
  • Thread starter Thread starter strangelittle_girl
strangelittle_girl
I have a problem: in a technical design I would like to connect the textual content of certain spaces to an excel file. is it possible to connect the fields to the excel file cells so that by changing the fields you change the drawing accordingly? ?
I'm desperate, please! !
Well, there's this recent discussion, and it's flawless though, for that I understand, it's not what you want.
http://www.cad3d.it/forum1/showthread.php?t=32123read it can always be useful to you:
...the only thing you can do is connect a xls file to a table
I add only, maybe to the girl may interest, that a table can also be of one cell and without borders, in such case it is displayed as a normal text.
this makes it possible to update the text-cell to change the excel file.
Good morning, I wanted to know if there is a maximum number of links to excel files that I can do in a dw design? and if it is editable?
@tristan thank you.
I wanted to ask something else since I found no answer in the forum: I created in autocad 2015 links with excel tables, I wanted to know how never automatically updates the drawings if I change something in table excel. (I have to repeat this operation for 90 sections and it would be useful and convenient if I automatically update the links without having to open each dwg and update them manually). I hope I've been clear
I wanted to know why it doesn't automatically update the drawings if I change something in the excel table.
beautiful question...it would be necessary to turn it to the autodesk developers; I can't tell you. Maybe it wasn't possible to do an automatic update... I don't know
I solved it with a lisp. in the moment of publication updates both the press and the file, the putroppo lisp I found it only for the German version (version that I use) thanks for patience and I believe that a similar lisp also exists in Italian, if I find it I will signal it immediately! ! !
Well, you could put the link to the German lisp:)
so if the Italian version doesn't exist it could make one of the magicians of the cad3d lisp
No?
