connect multiple broken lines in a polylinea
  • Thread starter Thread starter Giovannino60
Giovannino60
connect more broken lines in a polyline, I have proato with me join but alcine lines are interrupted and not me joins them , I tried with region, but I can not and to control all the bits I would spend a lot of time, what I can do.
Tell me how I do the group. Thank you.
I clicked on the command line group, new, put the names, selected, ok I returned to the drawing I clicked on above nothing changed.
you need to check the "selectable" option. Now I don't have 2007, but I think the interface of group creation has remained the same.
I can't, now the names have been etched and I can't even get rid of them so they don't mess up, with regrets.
This is the mask, see image. I don't understand.
to avoid confusion, delete the created group with removes, then create a new group with the "selectable" option checked.
and you will have all your selectable lines, as if they were a block or one item.
I can't remove it. before I clicked remove, is the mask scattered the drawing appeared and what should I have removed the drawing? I tried and nothing changed.
now however remove it has become gray, see image. Anyway, it came out when I started. What do I do?
I'm wrong, I'm sorry. Exploding it with explosives. That's how you get rid of it.
Then I'd re-create the new group.
it does not even eliminate with explosions.
but the group that difference has compared to the block.
introduction to groups (conception) by the online guide of autocad:
a group is a set of objects that you can select and edit together or separately. groups represent a simple system to combine design elements to manipulate as a unit. you can create them quickly and with a default name.
Suggestions groups are useful to associate solids 3d if you do not want to combine them with a boolean operation.
you can change the group components by adding and removing objects.
Similar to blocks, groups allow to gather objects in a set to which a name is assigned. created groups are saved for each session. Unlike blocks, however, you can change the individual items included in the groups without exploding the group. groups can also not be shared with other designs.
a group is such in the dwg in which it is created, if dragged or copied into another dwg each object returns "single".
the most trivial thing I had not tried :biggrin:
I thought about the connection by xrif
Hello and thank you
