connection bolted, no hole selection
  • Thread starter Thread starter MckJapan
MckJapan
Hello everyone, I should create a bolted connection to the two objects in the photo.
the holes were made with a simple 8mm circle during modeling 2d.
between the hole of the central part, and the two on the sides there is a 0.5mm game, so the holes are not directly in contact.
I tried to align the parts both through constraint, and through pin (the latter is what I should use, as the part will be mobile then), but when I go to create the bolted connection by hole, after the selection of the initial plan, it does not make me select the holes. It doesn't give me any mistake, it just doesn't seem to recognize the holes.
Did you happen?
holes to be recognized as such must be created with the special hole or hole command
