consigli render
  • Thread starter Thread starter kubbah
kubbah
Hello
I address myself to you experts since I should make first renders with revit
Can you give me advice on how to do this?
I mean... If you think the best procedure is:
1. for example export files to 3ds and make cn 3ds
2. export files somewhere else and make the render cn that program
3. make it directly from revit by clicking on "show rendering dialog"
I've heard of mental ray, is it an outside program? How do I integrate it with revit??
In short, what is the procedure according to you best to make the renderings of an object made with revit?
I predict that in my case it is a very large complex, with many objects etc..
Thank you
but do I have cmq export the file and open it or with 3ds or with mr?
Is mr integrated perhaps better with revit or not?
3ds I already know how to use more or less:)
Never opened. .
but mental rey is the window opening within revit 2009 quadno clicco on the icon at the bottom first named. .
or is it a totally external application, and to use it first I have to export object 3d?
mental ray is not a software apart... is simply the engine to render which is included both in revit and in 3ds max. So you don't need to export any 3d... work directly in revit, apply the materials, set the lights etc.
I read around.
since it is the same as 3ds say that there is no more bisongo to export and you can get very good effects
Of course with 3ds you can get excellence
but with this they say that you can get good results to make
revit recommends removing non-necessary families to speed up the process
Do you have any other rabbits?
For what concerns me revit is absolutely much more intuitive than 3ds especially for the render phase..
It's true that with 3ds you can get rid of more, but in the end the product that comes out from revit has nothing to envy especially if you make a relationship "wanted effect"/"time to learn".
If you want a render with many objects, maybe for an interior to make it more real or livable.. of bookstores there are not so well made as for 3ds and create them.. is a little long and complicated.. (imho) alternatively, which I exploit very often, I take from 3ds objects that interest me in dwg and then they amount on revit.. :
mental ray is also in 3ds, if you learn well revit, do the same renderings, with much more speed than 3ds, if you work in architectural. (if you want to do animated puppets, go better in 3ds ..)
you do not have any problems with tilings to do, and other technical problems that you typically have when importing export, or when working with polygonal models, or with radiosity he corners of the rooms.
all things that those who have had the opportunity to make some rendering and architectural animation, know well ...
mr is a rendering engine with enormous potential.in revit has been implemented in a "soft" way for what in autodesk consider to be the needs of an architecture studio, which should take care more of the design accompanying it with exemplifying images, but without investing working days in their elaboration. This does not take away that you can get excellent results.in 3ds mr is implemented at the top of its possibilities, it is a bit like to pass from great tourism
Hello, everyone! I searched among the various posts but I did not find the answer
I read the guide:http://www.frcprogetti.com/news/2008/11/12/tutorial-revit-architecture-i-settaggi-di-mental-ray/but I didn't understand to have a night rendering like I have to do,
I mean... do I have cmq lascure the sun on?
or use "only artificial lights"
If I should light the façade from the outside?
with a lamp??? co there are kind of lights as in 3ds that allow to illuminate an object as if it were a torch. .
thanks for the advice
and there is the possibility to define I do not know a level of global lighting (as in 3ds) ?
So maybe I light it out a little bit. .
first of all is it a rendering of exterior interiors or both?
What kind of effect would you like to achieve?
with mr the light has a real behavior, so if imposed as date and time that I know, August at noon I will have an intense light with clear and defined shadows, August at sunset I will have a less luminous intensity and softer shadows, even the colors will be more tending to red.
with regard to the use of lamps, from the propietà you can set type (halogenuri,incandescence etc.) and intensity. If you enter the propietà of the light source you can choose how the light spreads. the ideal would be to use photometric diagrams in order to have a diffusion as real as possible.
grit
but is there a possibility of using a "global illumination light"?
This is a night-time light, moon type that illuminates the whole. .
Except that some of the forums don't forget me, I don't think there's a moon effect.
However, you could set "only artificial lights" and insert one or more light arises
with power and type of light set to suit.
the light sources are not rendered, so with some evidence you could be able to create an ad hoc lighting, a little like you did with the first rendering engines.
I use this 3d to not create another one.
I need help!
Why if I create a jpg with revit is viewable on my lcd (via usb input) and if instead I modify the jpg with photoshop, I insert the sky, I rise in jpg, it is no longer visible (by format error, and the jpg is the only one who is able to read)? ?
remedies?
Thanks
where is no longer visible?
an image file (almost all common types), are importable in revit
no then I create a render with revit, format jpg.
This jpg is viewable on a 42 inch LCD TV that I have on another side, via USB stick.
If I create a render with revit, format jpg, I insert the sky with photoshop and I rise in jpg, this is no longer viewable on my television. It tells me wrong format.
Why? Does photoshop change some parameters? And yet it is still a jpg!
I think it's a modified file problem with photoshop.
try to change the save format after editing with photoshop, to see if it is readable from TV
