constructive details
  • Thread starter Thread starter Horo
Horo
Hi to all boys I am practically new to this forum, so I apologize at the start if my request was not expressed here!, then I would need if it is possible some constructive details, in practice details, no example how are the foundations to igloo or or loft in lateral-cement example of full insole stairs, connection knots between foundation and walls or internal wall and various things...I would be there for your "with
greetings horo
if you tap the forum (or use the "Search in this forum" button - the right button at the top) you will find various discussions containing links to references of various sites with the resources you are looking for
that answers are proof to see in the forum with the search button...if you have to give a help from the sixth and do not wash your hands with the search button...that all mensionate it but in the end never seeks anything you need!
Maybe then a moderator explains it in detail, anyway:
- to participate in the forum there are rules: http://www.cad3d.it/forum1/showthread.php?t=13677and you violated at least two of them with your previous post
- the "search" function, if well used, is a very powerful tool. If you can't find anything, I guarantee it's because you've lost too little time, or you haven't used the right keywords. on this forum, the vast majority of us use very well-designed keywords to open the various threads, so the "search" command works here.
- using the "search" command takes advantage of your time, opening a new thread exploits the time of others. think about it before you do it again.
about creating constructive details for an executive design with autocad.
in the architectural design that I possess all the quotas present are at the end; If I wish to make particular constructions with thicker floors, does the building leave?
because the architect designed a (solar+ finished floor) of a thickness of only 35 cm
There are regulations on this, what?
