contact
  • Thread starter Thread starter karalu
karalu
Good morning to all,
I'm doing a thesis job and I should do simulations to reproduce compression tests. In this regard, I used the "contactsurf" function to create contact between the upper plate and the structure to simulate. inside the "interfaces" panel I selected as a type " slide" as I need that during compression the nodes of the structure are not completely bound to those of the plate, but the relative shift between the two components is allowed. When I launch the simulation, I get this result... where presumably wrong?
grace to all in advance
