content center missing (and other cascading problems)
  • Thread starter Thread starter algio
algio
Hello everyone!
today while working with inventor 2008 I dragged to the lower left corner of the screen the window of the content center, to better see the piece I was working on. After that I couldn't reopen the content center anymore.
I couldn't find the window anywhere. and also closing everything and reclicking on tools->content center editor I see the hourglass for a couple of seconds after that nothing even receives error messages (and until I press the esc key I can not operate on any menu or do anything else within inventor).
after desperately searching on google solutions for this problem I decided to uninstall and reinstall the program.
a first simple uninstall from control panel did not result. once the program was reinstalled, the situation was identical.
then I tried this more "radical" uninstall procedure http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteid=123112&id=9979481&linkid=9242018 and panic more total I also erased the files connected to inventor who resided in the date folder of the microsoft sql server (I first backed them up, all following another page of the autodesk help which I now do not find the url).
I believe that as a result of this now gives me the error that I attach to you and continues to give it to me while having restored the files of the sql server.
I mean, a little bad luck a little my anxiety and the subsequent mistakes have driven me into a difficult situation to get rid of.
Do you have any advice?
ale
I think I fixed it.
the content center was simply over the visible part of the program window. I brought it to a visible position, moving it with the keyboard instead of the mouse.
The other problem is solved by itself, I can't say how. I simply logged in to osql with the user vaultsys and a password found in a discussion of the autodesk forums.
Congratulations you managed to get a mistake never seen before!
cmq less bad for you. but then did you manage to remake the log in with your account?
Would you mind posting the autodesk discussion address with that password?
Bye-bye
Hello, diegus!
I don't know what you mean by login with my account, consider that I use inventor as a single user. but having deleted those files of the sql database I think I still created pastries and for that during the installation the adms could not lodge with its user vaultsys (or at least this is what I understood, the software creates a user of its own).
the discussion I referred to is this:http://forums.autodesk.com/t5/autodesk-vault/error-29001-vault-manager-error/m-p/1959662/highlight/true#m16438
ah, sorry for the delay of the answer but during the week I have very little time to check the mail.
Hi, Algio.
I have your own problem. I disappeared the content center window.. what do you mean to move it with the keyboard? I tried but nothing happens. Can you help me explaining better how to make the content center window visible?
