conversion from idw to dxf or dwg with scale quotas
  • Thread starter Thread starter Cimbo
Cimbo
Hello, I have a big problem, after conversion of a .idw table of inventor in dxf or dwg, if I go to measure the odds I find them in scale other than the real one
in the export card in dwg, there are settings to be arranged.
Three out of five give you an output in 1 to 1, the other two don't, check.
Besides, if you carry formats that have pieces, or details, in different scales, you will certainly find that do not match the real size.
is usually exported with the scale of the first view of the table
example, if you first saw the isometric with "balorda" scale (0.16... 0.11)) then all the rest even if in correct scale (example 1:2) turns out to be wrong.
the view is always for last.
a council that often other forums give... always valid, put a photo, a pdf. something.. .
