Maurog Guest Feb 21, 2014 #1 Bye to all, with the inventor version 2014 I have a problem in file conversion from the same inventor to autocad. the dotted lines of the recessed hexagons present on the tcei vines are "split" diagonally, I attach a file. Thank you very much Attachments Linee_impazzite.dwg Linee_impazzite.dwg 145.2 KB · Views: 9
Catafratto Guest Feb 21, 2014 #2 I remember that there is already a discussion about this: If you're looking for her well (I'm sick of looking for discussions, so arrange for it!). However this: http://beinginventive.typepad.com/being-inventive/2013/01/index.htmlis a site where the solution is proposed. Bye!
Maurog Guest Feb 21, 2014 #3 Thank you very much. I solved, very kind. I had looked for a lot the existence of a discussion on this subject but I did not find it. Hi.
Catafratto Guest Feb 21, 2014 #4 search for old discussions for me is always a problem, I have some talent in avoiding the right search words! happy to have helped. Bye!
MauroM Guest Feb 22, 2014 #5 I found her. http://www.cad3d.it/forum1/showthread.php?35881-soluzione-per-esportazione-corretta-in-dwg
