conversion stp files from medusa to inventor
  • Thread starter Thread starter fenice consulenze
fenice consulenze
Good morning, I write to you because I wanted a solution to a prolema.
briefly: a stp file created with jellyfish at the time when it is opened with inventor you see the pattern tree, but the 3d is not visible, indeed when you pass the mouse on it, you only highlight the boundary of the part and not all the assembling
How can you, according to you, do you also see the model of asses?
thanks in advance
Have you tried to check the setting of the various options while opening the step file?1612961539183.webp
