convert 3ds files to solid edge
  • Thread starter Thread starter SCERIFFO83
SCERIFFO83
someone knows how I can convert 3ds files to solid edge:smile:
I tried with riho but at the time of rescue it gives me a polygonal mash problem. there are other methods
the problem is that I have towed a furniture library and the details are saved in 3ds.
autocad nn opens them already tried the only one is rhino but then doesn't save me in a compatible format
zipper and attach here one of those .3ds furniture, we convert it into the formats you wrote, and you will control the quality in itself.
depending on your judgment, you will be advised of the most appropriate conversion method.
in the morning!
you have to convert to step or iges, you probably exported to stl.
p.s. is practice to include a brief description of whether and its activity in the specific discussion.
no I saved the file in iges or step from rhino but gives me a problem that does not convert polygonal mash and therefore does not save it
Sheriff,
You've already been asked not to wring in capital and make us available one of those furniture in .3ds... last call.
Thanks.....the acis file can open it better than the other two formats, although they are heavy to handle.
Can you tell me how you converted them? Thank you.
strange, after This is what I never would have said...
to convert to .sat, I used crossmanager.
from the program you recommended I can not find the method to directly pass those 3ds files in solid edge formats(psm,asm,par).... how do I do
