convert autocad 2d files
  • Thread starter Thread starter briele2
briele2
How can you copy past autocad files on inventor sketches? Is there a simple solution?
ctrl-c in autocad ctrl-v on inventor
I'm just thinking about making it to the "bocia". . .
alternatively in the sketch menu > insert autocad file
Thank you, the problem is that I'm using inventor fusion and there's practically no icons or references!
with merger 2012
after doing the sketch, click dx mouse -> "glue geometry of autocad"
with merger 2012
now I found out that in autocad 2013 there is in the plug-in menu
the possibility of "edit to fusion"
I don't know if you knew it, you should directly pass the car design to fusion
the problem is that he asks: no unlocked lay out (?????) and no nestings (??? ? ? )
I mean, I've been trying to use this edict to fusion that doesn't...
there's the insert--->file cad---> option, then it all collapses, maybe the design I want to insert is too big but it doesn't fit me even a bolt
instead someone knows how I can bring the 3d files of autocad 2013 in inventor?
I don't know... help me!
practically inventor for me is a completely new thing, in fact I am looking for manual exercises, who can give me a hand politely. . .
Thank you!
