convert multiple v8 3d files to 2d automatically
  • Thread starter Thread starter minis
from what you wrote, I don't understand if you modified or added the .bat file,
the msbatch file must remain "original" and must be added lance-msbatch with
string it at the bottom, then you have to click on the latter.
Did you do that?
ps: I tried on two other machines, and it works
solved I had made a typing error by wronging the link to the files, now it works perfectly and the files with blank brushes are automatically converted between the names
Thank you very much
I wanted to ask for another courtesy, how to automate another operation, which is the following
data a set of files
open them
launch the suitable view command
Save Settings
save the file
this automatically for all files
Thanks again
Well, I'm glad you solved, for your last request, you should feel trebbi, that I see follows the forum, he will surely help you
Surely you could help me but unfortunately for a fee and for now I am looking for advice to solve small problems, thank you however
Yes, trebbi is a guru with capital g on ms, has developed many truly brilliant applications.
Why don't you read the message better? I asked you practically a coffee, I needed to score on a site, elance.com (by the way, thank you)
as to your request, a couple of keyin are enough:
fit view extended 1
filedesign
put them in a macro and roll them as for the other
