copy a set and all its components
  • Thread starter Thread starter gymbg
gymbg
I would like to copy a set made in a x job, in a y job, without losing all the parts that make it
how can I do it without managing resources where should I select each individual component by risking leaving some?
...I better explain...I can copy and paste from the x work to the alvoro y of what I need the problem is that if I then make changes to the second job I also report them to the original...where I don't want them... .
It's inevitable that it is.
the only way is to give a new file name to the particular that changes.
another way you can make a pack&go in the new folder and change it all.
I often do so, then going to change only the components they need.
pro: the original folder remains unchanged
counter: duplic files on disks
