copy all the asses to another folder
  • Thread starter Thread starter tvi71it
tvi71it
Good morning, everyone.
I realized in a folder, a set consisting of dozens of parts, this ultratime also shaped by me in the same folder, which I then used to make the assemblies, with screws taken from the catalog etc.
now as the project, previews that during its advance, are frozen and issued various steps for sending to the customer, I thought well to create a new folder called for example step1 and copy in all the files of the modeling folder (catproduct and catpart) so that later, I would continue to work in the modeling folder, to continue with the evolution of the project and then use the same method to freeze other steps.
the problem is that the references of the parts that make up the axieme that I copied in the step1 folder, always point to the modeling folder, so I would not have frozen a good thing, in fact if I change any part in the modeling folder and then I open the step1 axieme, I see clearly how I modified, just because the references always point to the other side.
if of this step1 folder, I do a cd x the customer, at the time when it opens, (and I checked it myself), the axieme does not work, as he will have yes all the parts in the step1 folder, but the axieme references will always point to the files of the other folder.
How can I handle this problem?
thanks in advance for any suggestions
tvi71
if I have understood correctly ...................................... try using file/send to/directory ....... .
should practically copy your product files to a folder and be linked to the facts of them............
I didn't do any evidence and never use this test command and let me know:wink:
