copy in part and delete links
  • Thread starter Thread starter gerod
gerod
I found out this.
together with several pieces, many created with copy in the parts of the geometries I needed.
today I decided to delete all links so that the various copies of the parts became their own of each file.
had, I go to check some bodies did not find associated geometry (I find myself a nice exclamation point).
What can I do? (I can go back because I have backup).
I have eliminated the links directly from the genaral axieme, therefore from the highest point of the hierarchy.
above all I checked the broken links: All right.
the beauty is that the features disappear, some pieces are empty, others have 2 planes of reference (manca the third), the body there is but there are not the features that make it.
What a mess! (on this the st would be better!)
I open the original, with links, and it's okay.
mah, I think I use the model with links
However, this is abnormal
It seemed to me that if you took off the link, you would still leave a bodyfeature and just the copied piece and not lose everything.
try asking for assistance, maybe it is a bug of itself.
I don't have if I'm under my hand to try, but I'm trying tomorrow at the office.
I'm using 20 sp15.
I also agree with you that if the link is interrupted he should keep the surface (or copy in the part).
the beautiful is that on 400 pieces the large part maintain features and copies in the parts that are released, but some files are not and this is serious because I am having to control everything.
I would not want it to be a problem also of ram (arrival to the limit).
Alternatively I should release copies by opening each file (par and psm) but it is a work piece.
for now I solve by hand but it is not a good pleasure to be in these situations.
in assistance they have replicated the defect.
In fact, even to them for some files disappear plans, copies in the parts, features.
for some remains the geometry but without the features.
I thought of a ram problem but it's not like that.
I also thought that some files have sketches linked to asm.
nothing, the only way to avoid seems to unlock file links for files!
(b)
(b)
then it is a program bug... I will try with the st to see if this version is also the same problem.
(b)
will not be that you had inconsistent links and updated losing the feature?
No, all the links were ok.
I tried both the main axieme and the various subaxiemes that contain corrupt files (corrupts after deleting links).
If you send me a little together, I can test with st mp8.
are designs of customers of my client and I can not (already in assistance I recommended not to spread them): I signed a bond!!! I try to replicate the defect by changing something if I have time.
anyway I can install the st and try, so now I can do it since I continue the assistance!
