Giorgio77
autocad platform.
someone knows a method, a script that allows you to use the copy command, making sure that all the objects present within the selection window are copied, and when an object appears for a part inside and for a part outside the selection window (i.e. it is intersected), it is copied also and only the part of this object within the window, in short as if the object is also automatically broken by this command.
