copy of a .iam collection
  • Thread starter Thread starter costeel
costeel
I want to make a copy of a welded set to be able to use it as another piece by changing only two holes.
2 I save it by name together 3, but when I open it as a pair 2.
What's wrong?
thanks to all
What's wrong?
thanks to all
try making the pack and go. in the way you do links between the parties are kept.
with the pack and go connections are interrupted. (solution without pdm obviously)
What's wrong?
thanks to all
after saving the aid, he always points to the same parts. replace the ones you want to drill differently with different parts and you will see that it works.
