copy of a view with quotas from one sheet to another
  • Thread starter Thread starter UncleRotten
UncleRotten
I need to copy some views from one sheet to another. this as where we work we need two sheets for each piece, one with quotation for the realization by the supplier, and a second with some extra views for the verifications to the goddess. on both sheets there are some common views, and I would like to avoid doing double work every time. Can anyone help me? selecting the view and what is around us and making a trivial copy and paste only copy some notes (such as surface finish marks).
use creo 2.0 m100.
thank you all in advance!
Andrea
in the tab layout and document tab of the table, find the command move or copy sheet.
the command can be activated once you select one or more views, it will ask you on which new sheet to move it or copy it.
Thank you very much, actually the copy is made, but it does not take behind the odds nor anything else... Also because I find only now that a quota shown in one view cannot be shown in another, unless, of course, to insert it manually. . .
one part one drawing, we say that this has always been the prince rule.
a quota taken from model quota guide, will always be and only one, a quota instead can be multiple.
If you want to do something like this I highly recommend you create two distinct designs, one processing and one inspection accompanied by a dimensional report, adding all the inspection quotas and other views to your liking, otherwise you have to work with 2d drawing groups and you get out a mess.
