copy parameters from start files
  • Thread starter Thread starter D4n13l
D4n13l
I have a little problem that I can't solve,
I have to copy the local parameters present in my start files (see figure), in another file where they are not present, I tried with export relationships and with export data but without success,
Can anyone help me?
Can anyone help me?
Thank you very muchView attachment 53070
write a text thread with relationships for each parameter,
for example:
if exists("title")
title = title
title=
endif
copy all the text in the reports,
regenerate,
cancel reports
if a parameter already exists is not touched.
hinges
If you have to do it one time you should do it by hand, parameter by parameter.
if you have to repeat it on multiple files you can make a macro (just register it while entering parameters in a model). If it's a more articulated thing you can use model check where you can set the check if there is a parameter and you can make it create automatically. If you want to do it on many models you can use the probatch attached to a macro.
if you have to do it a single time you can also select the parameters rows, copy in the starting file and paste into the parameters in the target file
When I get back to work I try to use the model check hoping to roar.. . ?
if you have to copy all the parameters of the start part:
Export the parameters in xlm format and import them where you need them.
