copy part -- > multibody
cacciatorino
I don't remember if I asked this question before, I tried to find nothing.
I insert a assembly as a copy part in one part (I want to do a welded-finished management without using the features of together). The assembly is my welded, the par "son" will be the work containing mechanical processing.
I would like every part of the departure assembly to match a body in the destination part. Is that possible? from the first evidence it would seem no, which is not a great harm except for the fact that, when I put on the table the part that represents the work, I do not see the divisions between the various components and therefore seems a single continuous solid.
I'm using st10.
You should remove the check from "join solid bodies", for some reason I have never deepened, this check is read-only that prevents you from having individual bodies.
to bypass this problem is enough to make the copy as building body and then activate the bodies as project.
I had tried, I saw that so it does not give a weight to the part, I do not know if then we have other issues
