Max_77
Good morning to all, I am a fairly experienced operator of v5 cat, however I am in difficulty as a customer asks me not to use the "matrix reuse" command for the insertion of the bolt but wants each screw to be inserted individually. I ask if there is a specific command that allows you to copy items already present in the tree by dragging with it even the constraints so as to avoid having to manually put them one by one. at the moment the only solution I found is to replicate the pieces with "multiple recurrence" but then they are all bound one by one. both with solidworks and with creo exists the possibility of "copying with couplings" also exists in catia? Thank you.
