copy surface from one model to another.
  • Thread starter Thread starter Alex70
Alex70
I would like to ask you if there is a solution to the problem that I have faced with catia v5r20.
practically, with all the options of the activated case (keep connection, etc), copying and pasting with retaining connection, I failed to maintain the surface of origin and that copied and pasted on another synchronized part.
I press that the two parts are contained in the same product, mounted by default (sys corresponding) and fixed.
when changing the part/surface of origin, the second remains as at the time of copying.
What's wrong?
you should update the product to transfer changes to the copy.
If you stay on the supported part file, it does not imply updating the copy.
