copy the properties of a photo inserted in autocad
Angelo2449
Hello everyone,
with > ruleimm < you can change the brightness of a photo.
is it possible to transfer brightness characteristics from one photo to another with a dedicated command?
test with matching properties. It may be that it can transfer brightness values from one photo to another.
group 281 contains brightness
group 282 contains contrast
group 283 contains the "fade"
creates a special command if matchprop does not go (I do not copy ownership).
lettura valori
(setq l (vlax-get-property vlaobj "brightness"))
(setq c (vlax-get-property vlaobj "contrast"))
(setq f (vlax-get-property vlaobj "fade"))
e equivalenti per scribee
(vlax-put-property vlaobj "brightness" l)
(vlax-put-property vlaobj "contrast" c)
(vlax-put-property vlaobj "fade" f)
