copy windows between layout keeping layers frozen
  • Thread starter Thread starter poina
poina
I need some advice.
Suppose we have more layouts in autocad, for each layout I have to freeze layers (for example: having the same base, as it can be a flat of a house, I will have a layout in which I see only the floors, one in which I see the countertops etc... of course on the model space all these layers overlap, while on the paper space I will leave active only those interested in not creating confusion.
Now if I create a new layout and make past copy from the previous layout, the copied window will have all the active layers and then to clean the plant I will have to refreeze all the layers that I don't care about.
Is there a system to copy the windows between layout keeping the layers frozen?
I don't know in adt, but in autocad, if you copy a layout you have the layer settings of each single window of the layout.
you don't have to create a new layout and then copy it into the windows, just by right-clicking on the layout tab from the "move or copy", copying the entire layout.
perfect thank you by copying from the layout tab menu you create an equal layout with the same properties.
Hello, everyone. I'm sure but now I can't do it anymore, because if I cover a layout window from one file to another I lose the settings?? will I forget something?? Thank you
I resume this old discussion by adding that you can copy the layout, copy a window into the new layout and use matching properties
