correct approach to address 3d modeling
  • Thread starter Thread starter zetadierre
zetadierre
Good evening,
after a few months of working on this new software I feel ready to face the next step of proceeding with three-dimensional modeling, especially the news that there is compatibility (although I did not understand which) with the program of rendering artlantis.
having already worked with other modeling software, I realized that usually in pennies it is a matter of having to understand where to knock the nose (given with language more I understand the commands to use and succeed in having dimisticity with directions of extrusions, changes of objects, control of visualization and navigation). not having ever worked with parametric elements, however, I wondered if in vw modeling it is good to limit itself to using those, but in case this hypothesis is affirmative, how to do for "free" forms to be inserted manually in the project?
I always address myself as if I were talking to a audience of people, but being discounted and well known that in this phase of growth of the forum (there are not so many in Italian on vw and I hope that it can become a bit the point of reference for users interested in deautocadizzarsi) the pillar carrying style de stij cul on which they hold all plans is called lory.b, I implied that if there were no other to an efficient start that can for inertia bring the mind of those who have been launched in this world to walk alone and discover the lands and borders registered vw.
Let's start by points.
There is a special plugin, developed by the abvent, which allows export from vw to artlantis. when you update the 3d on vw you also update the export without losing your settings set in artlantis. find it here http://www.artlantis.com/index.php?page=download/plugin/indexfor the 3d instead, do not put limits. parametric objects are very useful, but they cannot always meet our needs. especially when it comes to working on the recovery of existing and dated artefacts. for this modeling is important. vw tools for modeling are very valid. Try to explore them.
here you find tutorials (I suggest you start with the one on vw architect): http://www.nemetschek.net/training/free_resource.php, which guide you to the use of parametric objects.
Some videos about solid modeling find it here: http://www.nemetschek.net/library/index.php?movie=2009moviesBut that's not enough.
my advice is to take your hand with the environment 3d. organize well classes/categories. correctly use layers/glosss as model containers. the best thing, when it comes to building a building and to divide each floor on a different layer.
use a lot of the numerical keypad to change the views together with the flyover tool (I don't remember the name in Italian) to rotate around the model.
the best thing is that you begin, with the help of the help and the manual, to study the tools for modeling. and from time to time we can talk about it when you have something to clarify.
I do.
Well thank you!! We can start right away.
I have to make the 3d structure of an avancorpo composed of plywood beams of steel probe for water panels etc.
I am doing the constructive details starting also from forms are provided by vw as pillar beams etc under the engineering menu.
What I did is a section of all a portal. I would like to build elements in 3d so that it can export them directly to artlantis
We start very badly though. Ipe profiles and he can't understand why he doesn't make them in 3d!
lory.b,
Even if I don't know English the videos you posted are teaching me a lot of things.
Thank you!
I try: do they exist equal in Italian? I know they don't exist but try not harm.. .
Good evening! !
seems to me the correct procedure
should not be 3d but only two-dimensional. but you can do this: once you get the profile you need to convert it with command+k so it turns into a polyline. put you in the correct view and extrude it.
I do.
Thank you, I'll try early tonight or later tomorrow morning. . .
I almost got to the end of the video...
feel a little... a simple question but that may be useful. .
when it comes to "plants tags" shows how from an arc you can place a series of trees. it is seen that presses on the key corresponding to the Italian territory (tols set) and then on the tree. then paja as well in the options of inserting the row of trees!!! but I don't have it!!! Why?? Italian version or simply a magazine?
lory.b will make you a monument sooner or later
I just realized I only saw one of 50 videos
1)I apologize for the unrelevant question
2) I promise I stop using threads as a chat
50 videos??? "Mom," but where are they? I am almost going to give up learning vw just for the total lack of teaching information on this program... is the least supported in absolute, on the web is not found an hour and interesting books (like that on modeling 3d of j. pickup) are for sale only in states!...
I'll be wrong. . .
C
I don't remember the version you have. However those are the instruments of vw landmark. if you have vw designer you just edit your workspace (which I don't remember how it is translated, maybe work scheme... :-\) or select that landmark with the corresponding tools. If you have vw architect you only have some stuff like roads, but no trees.
I do.
I'll be wrong. . .
C
I said 50 to say, because yesterday I stayed enough to see one and then I realized there are many others. look in the link posted by lory.b riddle!! !
