correction macro solidworks
  • Thread starter Thread starter LineAT
LineAT
Good morning.
I tried to ask chatgpt to create a macro that copies me the name of the active document in solid works in the notes and this is what he gave me:
option explicit
sub main()
dim swapp as sldworks.sldworks
dim swmodel as sldworks.modeldoc2
set swapp = application.sldworks
set swmodel = swapp.activedoc
if not swmodel is nothing then
dim filename as string
filename = swmodel.getpathname
if len(filename) > 0 then
' copies the file name in the notes
dim dataobj as new msforms.dataobject
dataobj.settext filename
dataobj.putinclipboard
end if
end if
end
It is actually one of the options I give, but they always have the same problem or "types" or "objects" not declared or invalid.
can you correct it or understand what's wrong?
update: theia generated me a working code, I bring it back below:
option explicit
sub main()
'copy the active piece code in the notes
swapp.sendmsgtouser "code copied in notes"
dim dataobject as object
set dataobject = createobject("new:{1c3b4210-f441-11ce-b9ea-00a006b1a69}")
dim nomefile as string
filename = left(filename, instrrev(filename, ".") - 1)
filename = right(filename, len(filename) - instrrev(filename, "\"))
dataobject.settext filename
dataobject.putinclipboard
end
You can close.
