gafra
Hello everyone,
I would need some clarification
on the use of cosmosfloworks: from the tutorials I saw that it is possible to do "internal" analysis o "external" to the model; I have the need to study an iron block with internal heat generation in which there is a cooling circuit with circulating water and also the outer surface of the block radiates towards space. I tried to simulate everything by proceeding in two ways:
1) with internal simulation and setting external surfaces as radiant;
2) with internal simulation and non setting external surfaces as radiant;
but I think that the results are identical, in fact when I try to analyze a section of the system I do not see the field of temperature in the outer space, but the coloring only affects the block.
If you can help me, I will be immensely grateful.
greetings and soon
Gafra
greetings and soon
Gafra
