meccanicamg
Of course, if you are not in cycle times, try to use the whole couple to accelerate but in addition to triangular behavior you do not go. so the engine does not conceal. or engine changes or take longer times.Thank you very much for the answer.
as reasoning is there.
But I put myself in the situation of having to adapt the process to the possible availability in a motor already purchased and present in stock.
For example by making some calculations and assuming acceleration in the initial phase, I noticed that the necessary pair was too high compared to that of a motor I thought to use, so I will have to review the transitional time.
