covering entities and images without grip
  • Thread starter Thread starter jamirosauro
jamirosauro
with autocad 2012 (sp1) I have the problem in question. by inserting a covering entity or an image and selecting them, the grips are not shown.
on two other posts, always with autocad 2012 (sp1) the problem does not arise. I have verified the status of all system variables that have to do with grips, and are all set with the same value.
Any ideas?
first you checked that in options -> selection board checked the "active grip" option?
Of course, I did it for scruples, even if the problem arises only with the covering images and entities, all other grips are alive and vegeti :smile:
Unfortunately, the fact that the problem arises on two out of three cases, at the same time as general settings, does not allow me to understand the solution.
No, I was talking about three autocad licenses 2012. on two comes my problem.
all three have the sp1 installed.
I made an extreme attempt: Uninstalled autocad 2012 and reinstalled without sp1. same problem, so sp is not responsible for malfunctioning.
the problem is not the file, but I fear the sw or worse, the pc.
the same file on which I do not see the grips of the selected image, does not give problems open on the license of autocad 2012 that has no problem.
I did this, too.
the absurd is to have two identical configured machines, with the same sw, with the same variable settings and observe this difference.
:confused:
Good morning.
Just to tell you that autodesk technical assistance, it solved my problem.
Uninstalled the sketchbook designer plugin, the grips (of the images and the covering entities) are magically reappeared.
thanks anyway to everyone for availability.
