create 7.0.0.0 new installation
  • Thread starter Thread starter Daniele-san
Daniele-san
Hello.
Has anyone installed the new version creo 7.0.0.0?
if you have noticed such a message (see attachment)
I have not found any documents about it
Have you ever happened?
hi in the latest versions of creo have implemented new alerts at software startup, like the license will expire you in 15 days (that before nn there has never been). This indicates that you have voices in obsolete config.pro. It should work anyway. if you want to clean go into the options of creo and delete the voices with the red stamp (obsolete)
Hello.
This message concerns voices of the config, probably already "hidden" in previous creo versions, which in the future will be removed and then I create warns you to give you time to set up your workflow.
in my case the voice is regen_failure_handling, look if you have it. If you take it off, you'll see that the warning disappears at the start.
At the moment I have not yet looked at how I create 7.0 manages the failures and what voice of config is necessary, but on the other hand came out yesterday :)
Good morning.
I deleted (as "comment" obsolete options with red stamp) but the message remains
I deleted this option and the problem is solved.
greetings,
