Dr.Lube
Hello again,
I would need an address on how to create an automatic distinction of the objects I have in the drawing.
This is the distinct of the cords, which in my dwg are blocks with name, length, width. in the distinct will also appear the type of upper and lower iron with relative disengagement (it is here the problem!!)
in my lisp I will go to make a general dump that matches the lengths of all the blocks with the same label that identifies the type (e.g. c1, c2, etc.).
notice this information and that related to how it is armed below and above I will go to insert this dynamic block with the edited attributes automatically. for each cord will go to generate the properly modified block immediately under the previous one.
My problem is that I have no idea how to design the upper and lower currents automatically (I tried with a "series", but I can't control the step of this parameter externally. Maybe I miss something. .
in the annex you find the block "distinta_cordoli".View attachment distinta_cordoli.dwgresult I would like to get:
Thank you so much!!
dennis
ps. some writings have not yet been converted as parameters
Thank you so much!!dennis
