create a model of envelope.
  • Thread starter Thread starter Alex70
Alex70
I would need a tip to create a template of encumbrance with pro-e wf4.
I'll explain better: I made a set by managing the handling of a subaxieme through the connection of mechanism. now I would like to realize the model of encumbrance / envelope that this subaxieme generates in its handling: How do you do that? Do I have to go through the module animation?
you have to go into mechanism (applications > mechanism), set a servomotor (coil-shaped key) that moves your mechanism. do the mechanism analysis (throat-shaped cutter), after which you reproduce it (play key), in the latter command you find the possibility to make the envelope (shape button).
I hope I've been helpful.
Bye.
