save for all the holidays you start to sclerare near pro and
then of the file that I attached I have to build a solid that goes to fit perfectly on the surface but I do not know how to do it..who can help me?
use pro wf3
depends on what solid you want to do, for example you can do an extrusion to the surface.
or make your solid, copy and paste the surface you talk about and then with this make a cut.
or, if you have the aax module, do a public geometry in the part you posted and a copy geometry in the new part you want to achieve to have the surface to which you relate.
place your file with a possible solution (I don't know if that's what you need).
and an imported file as I copy that part.. .
and a generic thing just to understand how it works we say that I have to do the opposite of that solid as I can do?
