Be_on_edge Guest Nov 21, 2009 #2 you can add or remove material or divide a face. when you are in sketch environment you have to use insert - text profile (you can also be spread over a profile type arch or curve). Then apply the protrusion - dig - split face. Hi.
Be_on_edge Guest Nov 21, 2009 #3 I forgot, you can also use normal protrusion/scavo, in case the face is not flat. Hi.
