vitoditano
Hello guys, is there someone who can help me turn a mesh into a .stl model? I should use as software or catiav5 or geomagic design x. thanks.
Are you referring to the slate? You should try to editate it to make mesh congruent. . you can try the software I indicated before, of the gom (producing machine scanning both optical and tomographic). have a free viewer that could do for you. Although it is "only" a viewer allows you to do a lot of things, even edit acquisitions. . .I am in a condition in which I should reconstruct (or at least improve) a complex surface (frame) . I was looking at the form catia - reverse engineering but I seem to understand that you work on clouds of points or twelfths and, even for that said earlier, should not be the right way . I have a surface full of defects (overpositions, nodes etc.)
in addition to quote in toto what he wrote gianni, I apologize for misunderstanding, but here we were talking about reverse engineering on stl, not repairing corrupt models. . .No, actually, I only have a surface resulting from a statification process whose result (complex) provides overlaps and "pasticci" in various points. I was testing the catia module to try to improve the whole but it doesn't seem to me the right way (even if I might be wrong given the lack of use I made of it) . I asked if any of you had experience of this type and how to solve it in order to have a final use .
