create chains
  • Thread starter Thread starter fratello
fratello
Hello. .
I would like to create or in part or product design a chain (semplice chain) parametric that is adjustable that I can stretch or shorten at will.
it is possible to create one or it is too complicated
How do I proceed?
Can you help me?
you want to follow a trajectory (say a spline) that I can change from time to time...I can add or remove knits...you can do it?
do some repetitions in space is not so direct, when you can if your repetition can be reduced to a flat repetition.
more complex things are done only with macro or power copy.
if you can give an idea about the shape you can see which solution to implement.
