create coating of a structure similar to a boat
  • Thread starter Thread starter arrobb
arrobb
Bye-bye.
I need to understand how to create a coating for a similar structure
to a hull of a wooden boat.
I managed to create the skeleton, but now I have no idea how to shape a coating. I think you should use the mesh function, but it seems impossible.
p.s. use autocad 2011
thanks to all
I think you can use the superfsezdiv command (_surfnetwork):"creates a surface in space between different curves in u and v directions":smile:
I agree with the loft.
you have to create a series of profiles using the skeleton you have already shaped and then join them all in sequence to get the hull.
