create dwg files starting from a typical dwg and a db
  • Thread starter Thread starter enzo83
enzo83
good evening to all, I need help with creating some dwg files. I hope I can explain my problem: I have to create within a project a series of documents fundamentally equal to the layout level but change for some data values contained within it. I created typical reference with a set of attributes to assign. time ago, with an old version of autocad I found a program that through a database and the typical reference, generated the documents by changing the values inserted in the database from time to time. I'd need something like that. Can someone help me? is there any function in autocad 2013 that allows you to do this? ah I forgot, once the program was launched, it generated everything automatically.
and
