bisogna_rimanere_umili
I reopened algor after a while I didn't use it...
I uploaded a simple model, to apply the force in a hole I wanted to create the classic ray that distributes the load on the entire lower surface of the hole...
I create the mesh for the piece then select the surface that interests me, click dx and select "create joint" in the next menu click on "add" and select "universal joint" then on ok...
and nothing appears on the model, on the right tree adds a voice but only in the mesh and does not create any new part that would be the rays. . .
Where did I go wrong?
I tried again + times and I also loaded old files where I used the "joint mesh" correctly and if on the same file I try to remake them I can't.. .
Did Algor go crazy?
Did Algor go crazy?
