create level curves from a quoted plane
  • Thread starter Thread starter see3d
see3d
hello to all it has been for days that I look for free software that from a quoted plan you pull out the curves of level and its text with the quota but it doesn't exist just are all paid! I tried with autocad lisp ok but the text does not come next to the level curve! what do I do to buy it or do you have a solution? Thank you
if you have to do this one-time operation downloaded the trial of autocad civil 3d, otherwise I'm sorry but I don't know any free software that does what you ask
you ok curves come but are anonymous nn have share it would take another utility to name them
you could try with topocal, but it's been a while since I use it and news has so many
there are 3 versions, a free, a need for registration for the code, another is trial cmq the cost is 30 dollars for all the software in case you like it.http://www.topocal.com/Civil 3d even if you install it in trial is like a tir, i.e. you transmit a pin (your level curves) to everything you can do.
