hello to all excuses for the banal question but is a doubt that I want to remove, in rhino possible draw lines without duty at the end confirm with the left clik of the mouse every time?
depends how you don't want to do it, yes, you can, just enter the command bar the coordinates (x,y,z) of the last point and press sending twice, so you didn't use the left click
to not want to indicate the final point means that the lines you go to create must be tilt and default length. therefore all equal among them.
you can try with the copy command.
I actually wanted to draw 2d as we do with autocad without that click given line by line and I thought there was an option to disable it, but I guess not thanks
