create solid intersection
  • Thread starter Thread starter sottaceto
sottaceto
Hello, everyone.
I wondered how it was possible to change a component so as to remove the part that intersects another component.. possible in assembly environment.
Hello, everyone.
use Boolean operations, in assembly environment you can not do! !
So if I have 2 .catpart parts that overlap in a catproduct assembly file and I want to "should" them by removing the overlap from one of the two catparts I have to copy one of the two parts and paste it as "body" in the other and then remove it right?
ps: I have a problem with leotards. when I add a new one the previous ones are no longer visible (although in the tree they are present). What's wrong?
thanks to the availability!
for the first question it is okay to copy the body in the part! !
for the second sincerely I never happened! ! !
