create the edge from a block
mir
Starting from a block in autocad exists a way to get the edge design? I intend to get the shape of the object?
Is there a method?
bpoly
creates a rectangle around the block and uses the bpoly command, creates 2 polylines, which outlines the block and the inner part of the rectangle.
if you can create two layers where on one you put the lines of the contour and on the other the rest of the internal geometry, in this way if you turn off the layer with the internal geometry you only see the outer boundary.
