create the imprint of a piece on another both part of a assembled
  • Thread starter Thread starter bix
bix
Hello readers,
I am a novice user of catia v5 and I find myself having to solve my problem.
I have a file of assembled parts. I have to create the top print on the bottom that then interfere.
How am I supposed to do that?
thanks early
Can you post an image?
as you described it, I would be told to try to intersect the two parts in contact.
If, instead, they are in clash and you want to extract the whole area in clash, you can try with an intersect in the boolean operation section.
Maybe if you put an image I can get a clearer idea.
Thank you for your answer.
I hope the image is eloquent.
are three solids assembled. I have to recreate bugs that are under the red part, on the yellow part (matrix).
How do you do that?
in assembly design,
the product is the whole assembly
with three components with positioning.
rimozione.webpIf not you have copy restrictions between parts, you can copy paste with links but risk that the two parts do not align as you want.
similar way to solve the problem is the boolean of subtraction in the environment together (1).
select the subtract volume (e.g. partbody of the part1), in the window the part to which it must be taken (2), and where it must be placed in the tree (3).
will appear a feature of set in the tail of the tree (5).
